DIYnot
Local | Network
   DIYnot > Forums
Local | Network
CREDA GAS HOB - NO IGNITION ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
ashtonvillageuk
from United Kingdom
PostPosted: Tue Oct 26, 2010 9:48 am Reply with quote
I have a Creda gas hob which is about 15yrs old - the push button ignition for the gas rings has stopped sparking, any ideas - is there a battery involved ?
Many thanks !
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 873 times
PostPosted: Tue Oct 26, 2010 10:09 am Reply with quote
Look underneath for any signs of a battery cover or a mains lead to determine which type of ignition you have.Its not just been switched off at an isolator has it?
Back to top
 Alert Moderators
ashtonvillageuk
from United Kingdom
PostPosted: Tue Oct 26, 2010 10:58 am Reply with quote
Hi...thanks for the reply...there's certainly a mains power lead running close to where the push ignitions switch is - isolator switch is on !
I can't see any signs of a battery.
Back to top
 Alert Moderators
macfudd
from United Kingdom
Thanked: 35 times
PostPosted: Tue Oct 26, 2010 2:50 pm Reply with quote
It could be a stuck or broken ignition micro-switch or a faulty ignition generator.Either way it needs a Registered gas engineer to fix as it will require dismantling the hob.Approximate cost 60 to 100.
You can pick up a decent hob for around 100 these days so probably not worth repairing it.
Or just get a hand held battery igniter.
Back to top
 Alert Moderators
ashtonvillageuk
from United Kingdom
PostPosted: Tue Oct 26, 2010 2:53 pm Reply with quote
Many thanks - it will definitely be the hand held igniter !
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Creda Gas Hob Ignition Not Working 3 1440 Sat Mar 03, 2007 2:01 pm
Ignition switch on Homark gas hob 2 760 Tue Nov 20, 2007 1:06 pm
STOVES OVEN PIEZO IGNITION ELECTRODE 4 700 Wed Sep 10, 2008 1:47 pm
Gas Cooker - Ignition Problem 5 12260 Wed Dec 13, 2006 2:29 pm
Gas Hob Ignition Sparking Automatically 2 1080 Mon Oct 11, 2004 8:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
