Honeywell Accenta Mini G4 PIR problem
31 Oct 2010
London
hi,i have just installed the above system and on the walk test there are two problems:
firstly, on the lcd display, the TP shows 1,0. indicating a tamper i belive, which i cannot locate.
secondly, in the walk test again, the zones that have PIR's, are constantly showing a '1', even though the leds and not on on the pirs.
are all four PIR's faulty,can i reset the mains unit I have tried the reset in the manual and this does not resolve the PIR problem.
appreciate any advise.
Where is the AUX fuse, do you mean the fuses on the main board, if so, these are fine and so is the spur fuse.
Then check for around 13 v coming out of the AUX terminals and that they are the right orientation. If there is then it isn't a fuse. If not - then check the fuse with your meter. It's am matter of elimination.
joe-90,
sorry to sound dim, but what do you mean by AUX terms, The PIR's were functioning originally, so the power going to them is still the same, also which fuse is it that needs checking?. i cannot determine which fuse is specific for the PIRs if any.
You said they were not not lighting up did you not?
Open a pir see where it says +12 0V and meter that it will be dead.
Now locate 8 wires of the same colour from those terminals to the 8 in the panel which will be in one pair of 4 each. That will be the aUX your looking for.
found the problem, the speaker fuse had blown.
changed and now working.
thanks peeps.
