I have noticed that my outside light has a damaged section of 2.5mm T&E and needs replacing. It is damaged near the external hole in the brick wall.
This work has highlighted another area that may also require attention.
I have read that some people on this forum recommend passing the cable through a conduit as it crosses cavity. If so, what conduit do I use for 2.5mm T&E?
Many thanks.
Many thanks.
