DIYnot
Local | Network
   DIYnot > Forums
Local | Network
kangoo van 1.9 dci very fast idling
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Wed Nov 03, 2010 1:44 pm Reply with quote
hi guys
all was well until my timing belt snapped also taking out the cam (snapping it into 3 parts) we couldnt get hold of a topend from any scrappies as nobody would split so we bought a full engine and popped it in all works great eg starting and running etc but it idles at around 2500 to 3000rpm
timing is ok
also could anyone inform me of the location of the fast idle sensor (choke) or if it even has one?
cheers
Rich.
Back to top
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Wed Nov 03, 2010 1:45 pm Reply with quote
also as a trial and error we had all fault codes cleared and checked and this made no difference
Back to top
 Alert Moderators
andyandy2
from United Kingdom
Thanked: 11 times
PostPosted: Wed Nov 03, 2010 4:41 pm Reply with quote
I'd check all wiring and pipes on engine make sure all sensors are plugged in correctly, and any vacuum pipes etc fitted correctly.
If you have access again to a code reader see i've any codes have been logged again, could be something like maf sensor
Back to top
The following user says thank you to andyandy2 for this useful post:
supergas (3 Nov 2010)
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Wed Nov 03, 2010 9:24 pm Reply with quote
cheers,
im going to give it a full ay tomorrow (weather permitting)
Rich
Back to top
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Thu Nov 04, 2010 6:15 pm Reply with quote
checked all vacum pipes etc had a look round all wires and linked ecu to computer again and all was clear also changed the vacum pump over from my original engine and still no change.
any ideas or suggestions welcome
Back to top
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Sun Nov 14, 2010 11:54 pm Reply with quote
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 235 times
PostPosted: Mon Nov 15, 2010 6:19 am Reply with quote
its sure to be an electrical problem of some kind, does it have a throtttle cable or is it electronic?
Back to top
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Mon Nov 15, 2010 9:49 pm Reply with quote
it has a throttle cable that goes into a throttle position sensor and the pump is electrical, i am beginning to suspect the throttle pos sensor
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 235 times
PostPosted: Thu Nov 18, 2010 8:59 am Reply with quote
you could try disconnecting the battery for an hour or so to reset the ecu and then reconnect. Start the van and go for a drive rather than letting it idle see if it will re learn the position sensor.
Back to top
The following user says thank you to ch427 for this useful post:
supergas (18 Nov 2010)
 Alert Moderators
supergas
from United Kingdom
Thanked: 28 times
PostPosted: Thu Nov 18, 2010 9:37 pm Reply with quote
cheers ch427
i will try that, in fact id try anything, id even chop my left nut off to fix this van.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
406 td fast idle 2 420 Tue Dec 27, 2005 11:36 pm
losing oil fast 4 80 Mon Aug 29, 2011 8:27 am
Poor Idling Golf MK 3 6 480 Thu Nov 16, 2006 10:57 am
Ford Fiesta idling problems...help!! 7 1060 Sat Jan 12, 2008 2:36 pm
Astra Mk4 idling ploblem 2 560 Tue Dec 01, 2009 4:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
