yanto
Joined: 24 Apr 2005 Posts: 1 Location: Kent, United Kingdom Thanked: 0 times
Posted: Sun Apr 24, 2005 10:25 am Post Subject: ceiling light |
I am trying to connect a new ceiling light. I have two cables coming out of ceiling, one from the light switch one from the mains, the ceiling light has only 2(two) connections points. How do I wire them up, my wires are both red and black? |
fireman22
Joined: 18 Mar 2005 Posts: 605 Location: United Kingdom Thanked: 0 times
Posted: Sun Apr 24, 2005 10:52 am Post Subject: |
easy
1 connect red of feed to red of switch wire together in a connector block
2 black of feed cable goes to neutral or blue connector in light fitting
3 put some red tape around black of switch wire ( it becomes live when switch is on ) connect to live or brown terminal of light fitting
job done |
andy
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
fireman22
Posted: Sun Apr 24, 2005 10:54 am Post Subject: |
you will need a connector block of course and you dont mention earth cables if your feed and switch cables have earths these should be connected together in another block |
