DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Adding Inhibitor to Sealed Central Heating - HELP!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:07 pm Reply with quote
Huy Guys,
Heeeeeeelp!!!
I have one of these;
and one of these;
to dose the sealed central heating unit.
I have emptied the entire system of water....
I then attach the bottle to the dosing kit and screw it onto the filling loop. I then open the valve and it will NOT go in. Aaaargh!! I've squeeze the bottle so hard it nearly burst but the liquid will not pass into the boiler?!?!
What am I doing wrong? I can't see anywhere else in the system where I can add the chemicals. I don't understand why it won't go in. If I fill the system with water it goes in fine. icon_sad.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Wed Nov 03, 2010 5:13 pm Reply with quote
you never thought about the check valve in the filling loop
remove a radiator plug and pour it in if the systems empty.
Back to top
 Alert Moderators
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:16 pm Reply with quote
What's the check valve?
I tried to squirt it in a radiator and it just p!ssed out everywhere but in the hole. Maddening.
Back to top
 Alert Moderators
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:18 pm Reply with quote
But if the mains water passed though the valve when open why can't the inhibitor? :S
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Wed Nov 03, 2010 5:20 pm Reply with quote
mains is a lot more pressure than you holding a bottle.
can't see how it pi**ed out when you poured it in a rad.
check the iso valve is opening and not just the plastic lever turning.
Back to top
 Alert Moderators
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:23 pm Reply with quote
Yeah I wondered that. I tried to pour it in the bleed valve but it just poured all over the floor no matter how hard I pushed the nozzle in.
God this should be so simple. What other options do I have I just can't see where else I can add it? Cut my losses chuck the liquid away and use a concentrate to inject into a rad?
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Wed Nov 03, 2010 5:27 pm Reply with quote
i use a funnel on a tube that i've adapted to fit a rad and it never fails to fill.
Back to top
The following user says thank you to seco services for this useful post:
devellion (3 Nov 2010)
 Alert Moderators
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:31 pm Reply with quote
I opened both bleed valves on one rad and it just came out the other one. With just one bleed valve open it wouldn't go in as there is air inside and just went all over the floor. icon_sad.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1243 times
PostPosted: Wed Nov 03, 2010 5:33 pm Reply with quote
Back to top
 Alert Moderators
devellion
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 03, 2010 5:36 pm Reply with quote
Maybe I should try and pour it in an upstairs radiator that is more likely to be empty. The valves are open. Thanks for all your help. I've failed at this twice now and had to fill it back up again let alone wasted half the inhibitor.
I said inhibitor but I'm actually using cleaner as two of our radiators are very noisy in the morning ans wake us up. There is no air so I can only assume its debris the cleaner will remove.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Adding inhibitor to sealed system 3 480 Mon Nov 03, 2008 7:14 pm
Adding Inhibitor to a sealed system 2 1000 Mon Jan 16, 2006 11:54 am
Central heating inhibitor - how to add to sealed system 6 2420 Sun Sep 11, 2005 6:53 pm
Inhibitor in sealed c/h system..? 4 660 Wed Nov 30, 2005 9:27 pm
How can I add inhibitor to my sealed CH system? 14 5560 Sat Sep 23, 2006 2:37 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
