Hello,
I have Boilermate OV A-Class installed at home that we have recently moved in. I have realised boiler pump is allways on (i.e. boilermate's hot water function demands heat always). When I have opened up the boiler and checked the circuit board I have realised Middle sensor set to 75C for OFF. And When I have checked stored water temperature, it can reach max of 73C (this is with max setting at boiler). So due to heat loss etc. stored water cannot reach max temperature required by Boilermate which results in constant heat demand from boiler. Easy solution for me is to be able to reprogram the Middle sensor set point to a lower value (e.g. 72C) but I do not know if I can do it.
I appreciate if you know how to do it.
P.S. I am an electronics engineer and I might be able to reprogram IC on the board if I can find out data locations.
Many thanks.
Many thanks.
