DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Grant Vortex Combi boiler problems
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
ijb2302
from United Kingdom
PostPosted: Wed Nov 10, 2010 8:00 am Reply with quote
Hi
I have a Grant vortex 26 combi oil boiler. It is about 5 yrs old and has a couple of issues.
1. It doesn't seem to hold its pressure. I pressurise the system to 1bar but in a couple of days it reduces to almost zero but not low enough to trip the LP switch. There is a discharge from the PRV that must happen during normal operation. I have bled the system at the boiler and radiators and I have checked for leaks but can find none
2. The domestic hot water occasionally runs cold even when demand is low e.g. washing up.
I would appreciaye any help
Ivan
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 351 times
PostPosted: Wed Nov 10, 2010 2:57 pm Reply with quote
Check the charge on the exp vessell
Back to top
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Wed Nov 10, 2010 7:45 pm Reply with quote
Thanks I will try that.
I actually fitted anew one a year ago. The other was filled with water.
Back to top
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Fri Nov 12, 2010 7:06 am Reply with quote
I checked the exp vessel pressure and it was 0.95bar.
The system pressure was low again. I filled it to a preesure of 1 bar and fired the boiler. The pressure went up to 2bar+ and the PRV vented.
It seems that there is not enough capacity to cope with the expansion of the fluid.
Should I pressurise the system to to a lower pressure say 0.5bar
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 351 times
PostPosted: Fri Nov 12, 2010 9:51 am Reply with quote
Did you completely de pressurise the system before checking the vessell ?
How many rads are on the system.
An additional 18 litre vessell would help, as the one fitted as standard is only big enough on a small system.
Back to top
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Fri Nov 12, 2010 11:03 am Reply with quote
Thanks for this
Yes I de-pressurised the system.
There are 11 radiators. I have calculated the volume when I installed the boiler as around 80 litres which should be within the Grant stated maximum of 128 litres.
I notice that this is at expansion vessel charge of 1 bar and system pressure of 0.5 bar.
I have just checked after about 4 hours of operation.
After starting with the exp vessel pressure of 1 bar and system pressure of 1 bar when cold about 1 litre of water has discharged via the PRV and the system pressure (hot) is now 0.5 bar.
Back to top
 Alert Moderators
dcawkwell
from United Kingdom
Thanked: 513 times
PostPosted: Fri Nov 12, 2010 12:58 pm Reply with quote
ijb2302 wrote:
Thanks for this
What pressure have you got in the expansion vessel now?
If it has dropped the expansion vessel is at fault.
Faulty tyre valve on the expansion vessel possible.
Back to top
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Fri Nov 12, 2010 6:11 pm Reply with quote
The exp vessel pressure is still 1 bar so I think it is OK. It was new a year ago.
Back to top
 Alert Moderators
slapper
from United Kingdom
Thanked: 372 times
PostPosted: Fri Nov 12, 2010 6:44 pm Reply with quote
ijb2302 wrote:
Thanks for this
Why dont you fit a new PRV,it shouldnt discharge at less than 3bar and or 90degrees centigrade
Back to top
 Alert Moderators
Tibbot
from United Kingdom
Thanked: 347 times
PostPosted: Fri Nov 12, 2010 6:58 pm Reply with quote
Did you remember to allow for the 50 or so litres contained in the boiler in your calculation? That leaves only 78 to fill 11 rads and pipework. Extra vessel is probably required.
Back to top
 Alert Moderators
dcawkwell
from United Kingdom
Thanked: 513 times
PostPosted: Fri Nov 12, 2010 8:09 pm Reply with quote
Faulty pressure relief valve if it discharged at low pressure.
Back to top
The following user says thank you to dcawkwell for this useful post:
ijb2302 (13 Nov 2010)
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Sat Nov 13, 2010 7:17 am Reply with quote
Thanks that is a good point. I had not allowed for the boiler capacity so I am right on the limit. So it looks like another exp vessel.
Where be th best place to put it? The boiler is in a boiler room.
Back to top
 Alert Moderators
ijb2302
from United Kingdom
PostPosted: Sat Nov 13, 2010 7:19 am Reply with quote
Thanks. I have checked the PRV and it is OK
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 351 times
PostPosted: Sat Nov 13, 2010 9:38 am Reply with quote
Tee into the return pipework in the boiler room.
I would use an 18 ltr.
Back to top
The following user says thank you to Terrywookfit for this useful post:
 Alert Moderators
orinvolucri
from United Kingdom
PostPosted: Sat Mar 26, 2011 4:06 pm Reply with quote
We had a Grant combi boiler which 'blew up' in 2008 ruining much of the contents of our garage with dirty water leakage. It was replaced with a Grant vortex combi 26 by our plumber and has been trouble ever since. We've had a PCB replaced and the pressure always drops after a week or so well below 1 bar meaning the heating and hot water do not come on. It requires resetting every time which the subcontracted Grant engineer showed me how to do.
However, in using the one years extended warranty through Grant, the engineer found no fault indicating that we had to pay 235 to Grant. Their engineer only charges 57 call out fee! So, we are left with court case to fight (which we are presently doing) and a boiler that clearly has something wrong such as a faulty pressure vessel, pressure switch or similar. Moral of the story from our experience - avoid Grant boilers.
Any advice on how to proceed (legally and plumbing wise) would be greatly appreciated.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Grant Vortex Condensing Combi 26 hot water problems 30 8700 Sat Feb 19, 2011 3:45 pm
Grant Vortex condensing oil boiler 15/26 Problems 12 3580 Wed Apr 25, 2012 1:55 pm
Grant Vortex combi external oil boiler overheat 11 740 Mon Dec 24, 2012 1:55 pm
Grant vortex 26 combi oil boiler 4 100 Sun May 04, 2014 7:22 pm
grant vortex 36 combi boiler low pressure 5 740 Sun Dec 13, 2009 8:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
