Hi all,
I have a Bosch Greenstar system boiler with a ariston pressurised cylinder and been having an issue with my heating system for some time. Its been going on so long that i cant remember when it started. I had a potterton boiler before and that also had the same issue so it cant been the boiler.
I need to have the Heating on to enable the heating of the hot water tank.
On the programmer if i click on the "hour" button for heating the light comes on and the boiler fires up for and hour and heats the house. Howerver If i click on "hour" button for the water the light comes on and nothing happens, the boiler does no ignite? Therefore the only way to get hot water is to have the heating and water on together.
Would say this is not to pleasent in the summer however the rasiators have thermostats on so not been an issue until this week when now the hot water does not seem to be heating even though both lights for water and heating are on.
Can someone advise what the issue is likely to be so i can get the appropriate person in?
Electrical fault - Wiring issue? programmer not wired up right? Has no been touched?
Motorised valve issue? - How do i check they are working - i have two of them next to the cylinder in the loft? How do i know which one does what?
Many Thanks
Ian
Many Thanks
Ian
