Radiator cold until bled
11 Nov 2010
Nottinghamshire
Hopefully someone can help!
One radiator is always cold. The pipe to the lockshield valve is slightly warm, pipe to the thermostatic valve is cold - both are fully open.
Thermostatic valve pin moves freely and have tapped it a few times to make sure.
If I bleed the radiator and leave the water flowing it starts to get a bit warm at the top and both pipes get hot
Many thanks
if the rads full of air before you bleed it then it won't circulate till bled.
Thanks - water starts flowing as soon as I turn the bleed key!
Just tried closing the shieldlock valve and leaving the thermostat valve open - water flows from the bleed valve but if I push the therm valve pin in it stops - so I assume the valve is actually working! The water coming out of the bleed valve is warn too.
Am I right in assuming that the radiator may be sludged up?
