Dosing Sytem Through Magnaclean Filter
22 Nov 2009
Ayrshire
Hi all,
I was looking for advice about adding inhibitor through my Magnaclean filter. According to the manufacturers info, all major makers of inhibitor supply the correct adapter.
I've looked at a few, and they seem to only be push fit nozzles.
Can anyone recommend a product that can be easily used with the Magnaclean?
If not, could anyone tell me what specific adapter I should be looking for?
Regards,
Colin
i can't be arsed with the dosing things, i just unscrew the top and pour a litre of whatever i need in at a time.
only downside is the wonderful valves may leak if you use them and the main seal is probably could fail too. the main seal fails anyway so you are probably as well to replace it at the time as you dose.
the dosing thingy is often blocked/seized anyway.
Thanks for the reply.
Do you mean the main seal on the Magnaclean fails? Where would you get a replacement seal for that?
Regards,
Colin
