Wiring down lights using Ashley j501
14 Nov 2010
Can someone please advise me on the use of these junction boxes, and do I need to be able to pull them down through the ceiling, can I not fix them and have the cable long enough to connect to the fire rated unit?
I have 5 mains down lights with 11 watt bulbs, I intend to daisy chain 5 junction boxes via the terminals marked loop earth and Neutral which each have 3 sections, then run a cable from each JB using the same terminals to the light unit.
Picture and or diagrams always help
Thanks for your help
Martman
As long as you can be certain you will always have access to them, then yes you can fix them.
The whole point of the 501's is that you DO NOT need to fix them - they have cord restraint and are designed to be wired below and pushed up into the hole.
If you are talking about a loft, and are clipping the cables to the joists, and fixing joint boxes to the joists with a tail to the down light, as long as the joint boxes and cables are secured, you do not need the expensive 501's - a standard JB would be fine.
A joint box has to be accessible once installed - either from above or by dropping down the down light.
Yes they do, but you do not have to use them. They where developed to be used from below.
