adaptor for metal soil pipe?
29 Sep 2004
hi all
can anyone tell me if i can get an adaptor to connect 110mm soil pipe to a metal one (see photo)?
i've looked in the usual sheds but haven't seen anything obviously suitable. any help would be most appreciated.
cheers
Is the picture a pan connector? Look like an odd-sized clay pipe connector..?
yeah, the photo is of the pan connector that seems to be welded/concreted into another pipe. the second pipe is welded/concreted into the soil stack.
i was hoping not to have to break or cut the what's there already.
its not concreted it will be caulked with lead and hemp possibly covered in putty
it will come out if you go steady
I have seen a brown plastic underground fitting that would do it.
The product that will probably do it is manufactured by Polypipe, product number UG464 "Clay or Cast Iron Adaptors-110mm Adaptors to Sockets "
http://www.polypipe.com/POLYPIPE/pp_html/uground/ugd_frameset_05.html
thi is cemmented into the iron socket using a strong motar mix, so that the cement is made level with the outside rim of the socket and sloped forward onto the plastic fitting, should give neater result than a multikwik.
Not ideal , but u can get straight extension pipe which goes from 3 inch with sealing rubber to 4inch which receives the pan connector.
