DIYnot
Local | Network
   DIYnot > Forums
Local | Network
CED Photocell kit
Author Message
IJWS15
from United Kingdom
Thanked: 48 times
PostPosted: Mon Nov 15, 2010 9:40 pm Reply with quote
Picked one of these up from Toolstation . .
Looks like all the others - badged CED
Instructions do not mention earth and there is no connection, can I run three core pvc flex out through the wall to it and use the earth as the switched live (sleeved of course) or do I have to use four core and cut back the earth - there is no room in the unit for a connection block on the end of the earth cable if I use four core..
It will switch seven 2w LED downlighters in shower fittings in the soffit.
Edit - there will be about 2" of flex betwween the fitting and the entry point into the garage wall and a terminal box on the inside of the wall.
Back to top
 Alert Moderators
1john
from United Kingdom
Thanked: 340 times
PostPosted: Mon Nov 15, 2010 9:49 pm Reply with quote
Use the four core cable.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1144 times
PostPosted: Mon Nov 15, 2010 11:54 pm Reply with quote
You must not use an earth conductor for anything but earth.
Use 3 core and earth cable. The earth conductor must be earthed at the supply end.
If there is really no room in the CED unit then cut it back. It would be better to pop it into a small choc terminal block. There really is room in there.
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 48 times
PostPosted: Tue Nov 16, 2010 8:07 am Reply with quote
Sometimes when you ask a quuestion you know what the answer is going to be . . . . .
Now where in either B37 area or WS14 area can I get a couple of metres of black insulated four core?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1144 times
PostPosted: Tue Nov 16, 2010 11:38 pm Reply with quote
Any electrical distributor. Or on line from lots of places eg http://www.tlc-direct.co.uk/Products/HT1dot5slash4.html
Back to top
The following user says thank you to Taylortwocities for this useful post:
IJWS15 (17 Nov 2010)
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 48 times
PostPosted: Wed Nov 17, 2010 9:23 am Reply with quote
Thanks, missed that one when I looked.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Installing a Photocell Kit 6 140 Fri Jan 04, 2013 4:19 pm
2D 16W with photocell & pin question 5 100 Wed Jul 24, 2013 11:55 am
PIR with seperate photocell output 14 260 Fri Jan 06, 2012 10:53 pm
Photocell for decking lights 2 140 Thu Aug 11, 2011 12:59 pm
Photocell 15 1140 Fri Mar 11, 2011 6:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
