wiring diagram from a switch master 400 to a tempus 4
15 Nov 2010
Hampshire
Hi Guys,
Can you guide me on the transfer of wiring from the switch master to the tempus?
should be case of transfering the cables to the corresponding terminals, live, neutral, CPC, CH on and HW on.
my tempus switch has a setting switch on the back, for gravity or pumped systems. Also combined of seperate settings.
How do i check which one is for my system?
can you have heating on without hw ?
why are you changing it to such an old programmer instead of a later model ?
answer to the first question is yes.
I bought the 'new' switch on ebay, anything is new compared to the current switchmaster unit i have!
So, if the answer to that first question is definitely 'yes', you have a fully pumped system (I somehow doubt this). Therefore, your programmer should be selected for the 16 program setting and not the 10 program gravity HW setting.
Lucia.
