DIYnot
Local | Network
   DIYnot > Forums
Local | Network
System keeps filling up with air.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Tue Nov 16, 2010 9:11 pm Reply with quote
Hi all, was wondering if anyone had any idea what could be wrong with my sisters heating.
She has a Baxi Solo boiler, the upstairs radiators keep getting air in them, downstairs seems ok.
I air them and get the radiator warm then when the boiler gets turned on it just seems to empty and need aired again.
I did notice that the hot water seems to fill up in the header tank.
I very much doubt there is a leak as I have checked the manifolds and from there its 10mm pipe so there is no joins and the route it takes I would definitely see water, especially as it is 4 radiators worth of water.
After airing and getting the radiators warm, one of them is exeptionally hot even when boiler is turned to very low setting, not sure if this is relevant.
I'm not a plumber (spark) but would like to try to sort this, or atleast know a probable cause.
The hot water side of things, including immerser are ok too.
Thanks.
Back to top
 Alert Moderators
gas_man_gaz
from United Kingdom
Thanked: 75 times
PostPosted: Tue Nov 16, 2010 9:55 pm Reply with quote
is water pumping up th open vent? (the pipe that bends over into the top of the tank)
could be due to how the cold feed/open vent is configured.
could be a partial blockage causing the pump to draw air in from the open vent. could be the sys is producing hydrogen (you can test this by trying to light the gas which is bled from the rad)
any chance of some pictures of the pipework? where the cold feed & open vent enter the sys
Back to top
The following user says thank you to gas_man_gaz for this useful post:
BigJon (21 Nov 2010)
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Tue Nov 16, 2010 10:34 pm Reply with quote
I'll check exactly how its geting in there but it definately filled up, as the water was hot.
I'll check the hydrogen theory and get some pics hopefully tomorow as I know they tell a 1000 words!
Back to top
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Sat Nov 20, 2010 8:42 pm Reply with quote
Heres a few pics, not has a chance until now.
The boiler.
Directly above is the cylinder
Directly below boiler ( under floor) is the manifolds
In the attic is the tanks
The pics probably aren't great.
Would putting a cleaner in then drain/refill be worth doing.
Back to top
 Alert Moderators
ismellgas
from United Kingdom
Thanked: 14 times
PostPosted: Sat Nov 20, 2010 10:12 pm Reply with quote
try bleeding it from the air valve on the top insulated pipe at the front of the cylinder to get the air out the coil. also possible the pump is positioned in such a way that it is drawing air down the vent.
just ideas mate cant be sure..
Back to top
The following user says thank you to ismellgas for this useful post:
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
system not filling 2 180 Thu Jul 01, 2010 7:20 pm
Filling A Vented System? 6 860 Sat Nov 26, 2005 2:06 pm
Header tank full but not filling up the system!! 9 800 Tue Nov 15, 2005 9:02 pm
Frequent filling of closed central heating system 3 280 Sun Sep 26, 2010 10:55 am
Filling the system 22 880 Sun Apr 01, 2007 2:00 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
