I seem to be having 2 problems and I am not sure if they may be linked.
In the summer the boiler started to cut out with a fault code of F4 (ignition fault), with water on only, to correct this I would just turn it off and on again and it would then be fine for a few days.
I took the cover off the boiler and started it up and oddly the boiler was actually lighting, it was just the green light on the front which would flicker on and off, and then the fault code would appear, therefore I think this may be an electrical or sensor fault telling the system it is not lit when it actually is.
As soon as I put the heating on as well as the water it was absolutely fine and has been for about 3 months, until yesterday when it happened again.
About a month ago I also noticed water from a pipe outside my back door, I have traced this to the water tank and specifically one of the pressure release valves (tundish) indicating that the pressure may be too high in the cyllinder, this consistantly drains off when the boiler is on
I am not a qualified plumber or unvented specialist so will have to get a plumber in to have a look at this but was wondering if anyone had come accross similar issues and if the fix was expensive or not.
