I'm currently in the process of redecorating my lounge. The floor is a floating, boarded floor which is very drafty with gaps between each of the boards with noticeable amounts of air movement below.
As part of the redecorating, I'm wanting to seal the floor so as to reduce the draft as, obviously, this is making the room harder to heat.
I was thinking of putting some thick tape across the gaps in the boards but is there anything better I could do? I was also considering adding insulation underneath the boards to reduce the air movement - would this be advisable?
Thanks in advance,
Kev
Thanks in advance,
Kev
