DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing LCD / Plasma TV to drywalled / dot and dab wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual
Author Message
ilikewatchingtv
from United Kingdom
Thanked: 3 times
PostPosted: Fri Nov 19, 2010 12:57 pm Reply with quote
Hi All,
Just thought I'd post to help out anyone else considering fixing a TV mount to a drywalled /dot and dab wall.
During recent refurbishment work I decided to mount my LCD TV to a chimney breast which was due to be dotted an dabbed. After trawling the internet I eventually settled on using a fixing system called "Rigifix".
I've been incredibly impressed with the results, the fixing were simple to install, required one 12mm diameter hole 100mm deep for each of the 4 fixings I used. When the hole is drilled you insert a plastic sleeve, and screw in a metal liner using an allen/hex key, then simply attach your TV bracket to the threaded metal liner using the M6 bolts supplied. The results are neat, and impressively strong (apparently each bolt can support over 100Kg if fixed into solid brick).
A google search will reveal both the manufacturers website, and various retailers, although I actually bought mine from an eBay seller.
Hope this post proves helpfull to anyone else thinking about this sort of project!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 125 times
PostPosted: Sat Nov 20, 2010 8:50 am Reply with quote
Smells like spam to me, what do others make of it?
Back to top
 Alert Moderators
ilikewatchingtv
from United Kingdom
Thanked: 3 times
PostPosted: Sat Nov 20, 2010 9:55 am Reply with quote
Is it likely that I joined the forum over 2 years ago to spam this now? Also, my ebay ID is the same as my forum ID here, so if anyone suspects, they can see that my story re: buying this on ebay checks out icon_smile.gif
EDIT: Just to confirm, I thought that some forum members might appreciate my insight after spending several hours researching my options for wall mounting a TV on this specific construction wall, - I wish I'd found a post like this before I started, - would have saved some time!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 125 times
PostPosted: Sat Nov 20, 2010 11:05 am Reply with quote
Sorry, I thought I saw "posts 01" next to your post when I posted my reply. Either my eyes were deceiving me or there was a bug in the forum software.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Audio Visual All times are GMT
Page 1 of 1
Jump to:
Fixing Tv's to walls 3 260 Wed Oct 20, 2010 2:33 pm
Wall Mounted Plasma Channelling Wires Do I Need Trunking? 3 260 Wed Apr 11, 2012 7:50 am
Mounting a 42" Plasma .- Wall is concrete 3 200 Thu Sep 22, 2011 9:45 am
Wall mounting a Plasma or LCD TV 3 2260 Sat Mar 10, 2007 12:53 am
Distorted Picture on Plasma TV 2 100 Mon Sep 12, 2011 12:21 pm
DIYnot
