When my home number is called, the phone rings once and then goes silent, although the connection is made. The caller hears one ring and a lot of noise then, after about 5 secs, the line goes quiet. I can make calls out. I have found the BT master box in the loft and connected a new, corded phone which responds properly when my number is dialled - I therefore assume the problem is downstream of the BT master box. There are two cables coming out of the bottom of the master box. One goes to an extension socket (1) in an upstairs room where it terminates, the other goes to a second extension socket (2) in an upstairs room; from this extension a cable runs down inside the wall. Upstairs I have one more extension socket (3) with cable coming in and going out and downstairs I have 2 more extensions sockets - one with cable coming in and going out (4) and the other (5) with just the cable coming in and terminating (this is an MK extension socket with a capacitor).
I have a router with ADSL filter fitted to an extension cable fitted to extension socket (3) and a cordless phone fitted with filter to extension socket (5).
I have tried the line (using the new corded phone) with everything disconnected and the problem is still there.
I have checked all the extensions which all appear to be sound.
There is nothing I can think of that may have caused any damage to the extensions.
I have 2 BT cables coming into the house (one is an old line which is not used anymore and comes into its own brown, oval shape junction box in the loft and then down to a separate master socket). They appear to be touching as they run from the house to the pole-mounted box in the street. Could that cause the problem (as I think this problem arose after a weekend of stormy weather)?
Any suggestions gratefully received!
