DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton EP2000 replacement?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
AllsortsofDIY
from United Kingdom
PostPosted: Sat Nov 20, 2010 9:30 pm Reply with quote
My Potterton EP2000 needs to be replace (display faulty).
Is there:
1) a direct replacement (that requires no re-wiring). That is, it plugs directly into the existing back plate?
2) a replacement that requires slight wiring. If so, does the back plate require replacing or just re-wiring of the existing back plate?
Ideally I would like something from B& Q or Wickes (less than 50.00).
Thanks.
Back to top
 Alert Moderators
Tibbot
from United Kingdom
Thanked: 340 times
PostPosted: Sat Nov 20, 2010 9:35 pm Reply with quote
You can get most branded ones (except Honeywell) from Screwfix within your budget.
Back to top
 Alert Moderators
johnnojob
from United Kingdom
Thanked: 6 times
PostPosted: Sat Nov 20, 2010 9:42 pm Reply with quote
potterton ep 2002
fits same wall back plate.
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 397 times
PostPosted: Sat Nov 20, 2010 9:43 pm Reply with quote
The EPs are still available.
The 6002 allows seperate HW times aswell as individual days
http://www.uk-plumbing.com/Potterton-Electronic-Programmer-EP6002-7-Day-Independent-p-1284.html?source=googlebase
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 883 times
PostPosted: Sat Nov 20, 2010 9:51 pm Reply with quote
Anything other than an EP will require a rewire and a new backplate.These EP's were also used as a wiring centre for some systems and it makes the rewire a bit more involved.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton EP2000 Programmer replacement 2 1740 Sat Mar 06, 2010 7:21 pm
EP2000 Replacement suggestions 5 400 Thu Jan 08, 2009 2:16 pm
EP2000 replacement 4 60 Wed Dec 17, 2014 12:04 pm
EP2000 Replacement 8 100 Sat Sep 22, 2012 7:03 pm
Potterton profile EP2000 8 3340 Thu Jun 14, 2007 9:19 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
