baxi 105e combi
Status
Not open for further replies.
29 Apr 2005
3 yrs old keeps cutting off after short run on heating & hot water need to continually rest will not reset for 2/3 clicks then struggles to light fires up then neons come on to show a fault been checked by corgi installer who says it is o.k faxed problem to baxi in preston who do not seem bothered yto reply
somtines cobwebs in the venturi can cause similar problems......it only takes a few strands to stop the aps from making, have come accross this a few times.......
the whole boiler has been cleaned and serviced and today he fitted a new thermocoupler it worked for an hour until i ran the hot tap in the bathroom and ittripped out again
the lights flashing are above the flame and fan
i have sent a fax off to baxi who could not be bothered to reply so much for after sales service the engineer who is working on the boiler is the local baxi approved fitter and repairer where do we go from here apart from putting a hammer through it
sorry for thermo coupler it was a something like a temperature sender in an engine block
red neon is static over flame not flashing central heating is off when hot tap is turned on the igniter struggles to light for 3/ 4 attempts it runs and then will cut out with 2 neons showing and wil not reset with just 1 click back on reset button takes a few times for it to struugle to ignite
checked out price of pcb locally £150.00
no spark out of bolier for over 1 hour central heating on continous
but no light in boiler just blowing away with no spark
Yeah i got the 60c red light flashing i let some air out of rad as advised on here.Next day nothing on at all it was gushing water sounds in the said radiator that made me let air out as told.Gotta call heating company tuesday for appointment lucky its warm but hot water need too cheers!"
Status
