I have installed the above system with one door contact, three PIRs, one LED remote and outside alarm bell.
The main box has a problem in that I can trace the power from the boxes 230v power terminals through the transformer to aprox 13v at the point where it reaches the pcb terminals. The red power light does not come on until you push the multi meter test probes on the pcb's positive and negative terminals - as soon as you release the probes the power light slowly dims and goes out.
I'm working on the basis that there is a problem with the pcb power terminal block and will get the unit replaced.
Be that as it may - I have a couple of questions regarding the installation and set up process.
The manual states that for the walk test I must have the tamper link in place - is this correct - even though I have three sets of tamper wires already in the terminals.
It is unclear how the door contact is wired - there are I think five contact points which ones do I connect to?
Many thanks.
Many thanks.
