DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Metric to Imperial
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
GaytonTonner
from United Kingdom
Thanked: 3 times
PostPosted: Fri Nov 26, 2010 8:25 am Reply with quote
I have some old 1" imperial copper pipe to connect onto to using end-feed fittings. Do I need a 28mm to 1" adapter? Who would sell these?
On a general note does anyone know what sizes need a conversion adapter and what do not.
What about compression fittings? Do they fit each equivalent size?
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri Nov 26, 2010 9:09 am Reply with quote
1/2" to 15mm none required
1" to 28mm none req
3/4" TO 22MM Adaptor req
Compression fit the same but on 3/4 you can get a 3/4 olive for the 22mm fitting but a copper olive will work just aswell
Back to top
 Alert Moderators
GaytonTonner
from United Kingdom
Thanked: 3 times
PostPosted: Sat Nov 27, 2010 8:48 am Reply with quote
1" to 28mm none req
Thanks. So only (3/4" - 22mm) is there an issue on end-feed copper? Just to clarify.
I know 3/4" imperial olives are available for 22mm compression fitting. I would be weary of using a 22mm copper olive with 3/4" copper pipe. That is just me, I would not trust it..
Maybe this information should be in a sticky.
Back to top
 Alert Moderators
mysteryman
from United Kingdom
Thanked: 233 times
PostPosted: Sat Nov 27, 2010 11:55 am Reply with quote
Don't use 22mm olives on 3/4! You can also get 3/4 O rings for some pushfit fittings.
You may need to file inch copper down a bit to get 28mm fittings on to it.
Back to top
 Alert Moderators
GaytonTonner
from United Kingdom
Thanked: 3 times
PostPosted: Sat Nov 27, 2010 12:20 pm Reply with quote
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Sat Nov 27, 2010 5:27 pm Reply with quote
Piece of emery tape looped around the pipe, and pulled back and forth does the job.
Back to top
 Alert Moderators
GaytonTonner
from United Kingdom
Thanked: 3 times
PostPosted: Sun Nov 28, 2010 9:10 am Reply with quote
thanks.
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 341 times
PostPosted: Sun Nov 28, 2010 2:14 pm Reply with quote
Why not buy some 1" x 28mm Y1M, They are made for a reason.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
connecting metric to imperial pipe 2 60 Tue Oct 18, 2011 6:24 pm
imperial to metric pipework 7 220 Sun Mar 27, 2011 12:45 pm
imperial pipes and metric pipes joints etc 5 1060 Mon Mar 29, 2010 4:33 pm
Is My Gas Meter Metric or Imperial? 5 160 Sun Dec 08, 2013 3:32 pm
Imperial to metric 5 120 Wed Oct 08, 2014 8:05 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
