DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Electric or power shower MCB advice required
Author Message
ab123
from United Kingdom
PostPosted: Sun Nov 28, 2010 7:54 pm Reply with quote
My shower is knackered and I need to replace it. Currently have a 7kw triton biarritz electric shower on a 32A MCB protected by an RCD (hope I got that right), on a low pressure gravity fed water system.
The pressure I used to get from that was pathetic so I want one with more pressure/power.
I don't want to have to change electrics/wiring etc, just swap it out for something else (if that is possible), and I don't know about cable sizes.
1: What is the most powerful "electric" shower I can get for MCB type?
2: Can I change to a power shower, and will that be same on electrics etc / is it rated the same etc (I have no idea).
As you can probably guess I am not an electrician or plumber, so any help at a technical level I would be able to understand would be greatly appreciated.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1189 times
PostPosted: Sun Nov 28, 2010 8:13 pm Reply with quote
That cannot be right. Shjowers like this MUST be connected to the mains supply, not from the (gravity) cold water tank/.
Back to top
 Alert Moderators
DetlefSchmitz
from United Kingdom
Thanked: 91 times
PostPosted: Sun Nov 28, 2010 9:34 pm Reply with quote
...or the pressure would be poor...
Back to top
 Alert Moderators
ab123
from United Kingdom
PostPosted: Sun Nov 28, 2010 9:41 pm Reply with quote
Will recheck then...cold pressure is good, hot is useless
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 30 times
PostPosted: Sun Nov 28, 2010 9:57 pm Reply with quote
an electric shower must be connected to a rising main, if you have a gravity fed system then consider either a power shower or a pump and mixer shower
Back to top
 Alert Moderators
DetlefSchmitz
from United Kingdom
Thanked: 91 times
PostPosted: Sun Nov 28, 2010 10:23 pm Reply with quote
Though, of course, then you need hot water from your hot water supply, heated by some other means.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1969 times
PostPosted: Sun Nov 28, 2010 11:34 pm Reply with quote
You think that nobody has ever installed one like that because of gross incompetence?
No, it's not right but it might indeed be what the OP has.
Back to top
 Alert Moderators
londonboy
from United Kingdom
Thanked: 149 times
PostPosted: Sun Nov 28, 2010 11:43 pm Reply with quote
I cant find any information on this shower.
It could be a pumped shower on the cold downservice.
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Sun Nov 28, 2010 11:45 pm Reply with quote
http://www.showerspares.com/products/spare_parts/triton_biarritz_electric_shower
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1189 times
PostPosted: Mon Nov 29, 2010 8:49 pm Reply with quote
It is a classic electric shower that heats up water that is supplied under mains pressure. There is no pump in it.
To ab123. If you have a gravity system that provides you with hot and cold water to your bath then it would be better to install a shower pump and use the hot water that you already have.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Mon Nov 29, 2010 9:18 pm Reply with quote
You need to be sure exactly what what water supplies are available.
An appropriate thermostatic mixer will usually give a superior performance to any electrically heated shower, and adding a pump can make it even more so.
However, if you have gravity hot and mains cold supplies, fitting a mixer can be problematic unless you select one capable of handling supplies at different pressures, and fitting a pump to augment a mains cold supply is a no-no.
Some have used a pumped hot supply and a mains pressure cold supply, but that has it's problems too.
Any upgrade of your electrically heated shower would probably need completely re-wiring, as a higher water flow would need more electrical power to heat the water, as 7 KW is already near the edge of what a 32 Amp circuit will provide.
Many assume poor performance from an electric shower is caused by low water pressure. The usual limit is acually how fast the water can be heated with the available electric power. Increase the water flow, and all you get is a cold shower.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Advice Required R.E. Electric & Gas Meters 10 740 Wed Jul 22, 2009 5:27 pm
Advice Required for Electric work Already Carried Out 10 1260 Thu Sep 04, 2008 11:53 am
Power Shower - Earth bonding required? 9 440 Sun Sep 25, 2011 7:53 pm
Kitchen under unit lighting - advice required. 7 5080 Tue Apr 10, 2007 10:03 am
Re-doing electrician's work, cable advice required 26 800 Sat Mar 08, 2014 4:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
