DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant EcoTec Pro 28 Combi
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
KemikalAli
from United Kingdom
PostPosted: Sun Nov 28, 2010 9:30 pm Reply with quote
Hey Guys!
I'm newly registered to the forum but have been an avid reader of all advice regarding my central heating boiler.
It is a Vaillant Ecotec Pro 28 and was fitted about 3 years ago, it has been great until last year (around this time of winter) when the outside condensation pipe froze up, it backed up and started dripping water from the trap, it could not be defrosted with boliling water so I severed the 32mm outside and removed the rod of ice that had built up.
Unfortunately it is fitted on the most exposed wall of the downstairs kitchen where the wind blows the hardest.
Anyway, to cut a long story short it recently started to show the common F75 fault, I checked and repressurized the EV to 0.9bar, bled all of the CH heating system twice, checking for dead legs but the whole thing is fine and red hot when working.
The trouble is when the system gets to up to temperature or there is demand for hot water when the boiler tries to restart the CH system, it goes through the S1-S4 startup and then F75's, the only way I can get the system to fire is to add a little more water via the fixed filling loop and restart the boiler, the display also shows a S91 code (pressure over 2.9 bar) which is not suprising as the visual gauge is always in the red for the boiler to work. Water is constantly coming from the blow off pipe outside due to the excess pressure.
I have a new pressure sensor switch on its way which I should hopefully receive tomorrow all being well, I will fit this as soon as I get it as a matter or course.
So I'm my summing up before any of you kind gents can advise me, I believe the pressure sensor switch is knackered telling the system I need more water pressure, when the system expands when working at temperature the excess water is being driven out via the blow off pipe. the system water then cools pressure drops causing the F75, The frozen condensor pipe I believe is a seperate issue due to the weather!?
I took the condensor bottle out yesterday to find it was full of some kind of metal sediment, I cleaned and refilled this to 10mm from the top as per the manual.
I need to keep this boiler running as I have a severely disabled 9 year old daughter who needs to be kept warm.
All and any advice appreciated, thanks in advance
Kind regards
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3300 times
PostPosted: Sun Nov 28, 2010 9:34 pm Reply with quote
its more likely from your description that the canoe filter is blocked. Possible the switch is blocked as well. Probably doesnt need replacing. Why have you filled it so far? It should only be 1-1.5 bar. Release some water from a drain point. The "-" button should give you the exact pressure.
Back to top
 Alert Moderators
KemikalAli
from United Kingdom
PostPosted: Sun Nov 28, 2010 9:37 pm Reply with quote
Hi Mick,
Thanks for your quick reply.....
The reason for the high pressure is that the boiler shows a F75 fault and fails to fire if the pressure is anywhere less than near or in the red zone.
The pressure is taken from the LCD display using the method you advise.
This is my reason for suspecting that the pressure sensor is faulty!
Steve.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3595 times
PostPosted: Mon Nov 29, 2010 1:16 am Reply with quote
I would suggest you depressurise the boiler and refill the expansion vessel to 0.9 Bar but that must be done with the system pressure kept at zero. See FAQ for fullinstructions.
Last week I went to one of those and the pressure gauge was reading about two or three times the actual pressure.
Set the pressure to 1.5 Bar on the digital display and see what the pressure gauge shows.
The tube into the pressure sensor may be blocked and the pink ones are less reliable than the later black ones.
Tony
Back to top
The following user says thank you to Agile for this useful post:
KemikalAli (29 Nov 2010)
 Alert Moderators
KemikalAli
from United Kingdom
PostPosted: Mon Nov 29, 2010 1:20 am Reply with quote
Thanks Tony,
I will do that in the morning, the sensor is the later type black one btw!
Regards
Steve.
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3300 times
PostPosted: Mon Nov 29, 2010 1:43 am Reply with quote
while you've got the boiler drained i would take out the sensor and see if its blocked. and use a torch to check the condition of the filter that sits behind it.
Back to top
 Alert Moderators
KemikalAli
from United Kingdom
PostPosted: Mon Nov 29, 2010 3:58 am Reply with quote
The boiler went off around 2am, the house was freezing so I went to do some tinkering! icon_eek.gif
I isolated the CH system as well as the mains eletcricity, drained down the boiler and checked the pressure on the EV.... okay, depressed the valve and it dumped its entire contents into a bowl, around 10 litres, re-pressured the EV to 0.9bar, took out the pressure switch to find it was clogged with black muck, cleaned it, replaced and refilled the system, ran the PO purge programme..... PERFECT!
I bled the pump and lots ofc black gunge spilled out! .... time for a flush and treat after xmas!!
Thanks guys, you're the best!
Merry xmas to all
Regards
Steve.
Back to top
 Alert Moderators
Yukster
from United Kingdom
PostPosted: Sat Jan 04, 2014 11:12 am Reply with quote
I accidently overfilled the boiler. Initially the gage went up half way but when the boiler fired up the pressure gage showed 3 bar! I switched the boiler off and bled the radiator. The pressure went down BUT the boiler doesn't switch on and there's nothing showing on digital display, as if it's power is off.
I checked the fusebox and all fuses are on! Any advice on how i could resolve this?!?!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Combi Boiler Advice needed - Vaillant EcoTec Plus 831 3 1160 Fri Apr 11, 2008 4:57 pm
worcester/bosch 35cdi or vaillant 831 ecotec plus combi 2 2520 Sat Apr 01, 2006 2:37 pm
Vaillant EcoTec Plus 428 Combi + Triton Jade3 shower problem 7 100 Wed Feb 13, 2013 9:18 am
New Combi Boiler questions (possibly Vaillant Ecotec) 10 3840 Thu Aug 14, 2008 12:38 pm
Vaillant Ecotec plus 831 Combi - Vibrating Noise from DHW 22 5800 Sat Nov 27, 2010 1:22 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
