DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Screen washer jets not working
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
Alz0r
from United Kingdom
Thanked: 9 times
PostPosted: Wed Dec 01, 2010 10:39 am Reply with quote
Appreciate this is probably due to the cold but my jets aren't squirting. Reservoir is still liquid. Is it worth emptying / syphoning off what's in the bottle then pouring some hot water in? Not even 100% its frozen pipes because it got to a tropical 3 degrees yesterday and they still didnt work...
Back to top
 Alert Moderators
Mursal
from Ireland
Thanked: 268 times
PostPosted: Wed Dec 01, 2010 11:43 am Reply with quote
Yes most likely frost.
Turn on the ignition (don't start the engine) and turn on the washer pump.
You should hear it running?
If you can its frost and should be OK when things heat up a little. If you
cant check your fuses.
Back to top
The following user says thank you to Mursal for this useful post:
Alz0r (1 Dec 2010)
 Alert Moderators
Alz0r
from United Kingdom
Thanked: 9 times
PostPosted: Wed Dec 01, 2010 12:25 pm Reply with quote
It was the fuse! Cheers
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 151 times
PostPosted: Wed Dec 01, 2010 12:43 pm Reply with quote
Fuse probably went as you tried to use it when it was frozen.
Back to top
 Alert Moderators
PJF220
from United Kingdom
Thanked: 3 times
PostPosted: Fri Dec 10, 2010 12:13 am Reply with quote
Try using fluid with a lower freezing point. The 3 for 2 ready mix from a well known shop is only down to -6 and what happens is it exits the jets, some residue fluid hangs about the jets and is hit by the cold air and freezes, preventing more fluid coming out. You can make up your own fluid using ammonia/water/white vinegar solution as Ammonia freezes at -79 so even diluting down to 1 part to 4 parts water will keep it at -20. When buying fliud from shops, look for the ones with 'highly flamable' warnings as they will contain higher concentrates of alcohol. Think Vodka in the freezer... it doesn't freeze in your freezer, so high alcohol content in washer fluid helps reduce freezing.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
low pressure at windscreen washer jets 2 160 Tue Jan 11, 2011 1:15 pm
Windscreen washer jets strong at first then weaken 2 100 Sun Dec 09, 2012 12:59 pm
Water jets problems 2 340 Sat May 12, 2007 7:42 pm
Fiesta Encore 1.3 1997 Screen Washer Problem 2 740 Thu Nov 01, 2007 7:20 pm
Screen Washer Pump 2 840 Sun Dec 09, 2007 12:32 pm
DIYnot
