qwertyuiop
Joined: 02 May 2005 Posts: 20 Location: Banffshire, United Kingdom Thanked: 0 times
Posted: Mon May 02, 2005 10:23 pm Post Subject: bathroom lighting help please |
i have a low bathroom with a low ceiling - any recommendations on a suitable light fitting. not much room between plasterboard and roofing tiles (4 inches). light switch is outside bathroom in the bedroom |
delmel
Joined: 28 Nov 2004 Posts: 323 Location: United Kingdom Thanked: 0 times
Posted: Tue May 03, 2005 2:00 am Post Subject: |
100mm between void is fine for low voltage downlights, however you mention low ceilings. How low are you talking off. Stange to have the switch outside unless this is an onsuite. If not i would install on a pull cord. |
felix
Joined: 23 Jan 2005 Posts: 900 Location: United Kingdom Thanked: 0 times
Posted: Tue May 03, 2005 2:41 pm Post Subject: |
Is this a sloping roof? If it is I'd be tempted to put a false horizontal ceiling at the highest point with the wiring above. You don't need much width for a fluorescent light fitting and a pull cord switch.
PS: If you have a 4" void between the plasterboard and the tiles why isn't it full of insulation? |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
qwertyuiop
Posted: Tue May 03, 2005 10:52 pm Post Subject: why no insulation |
because its old (conversion done in 1940's i think)
i was going to take down the wall covering (tongue and groove) and properly insulate roof. however, i think i would need building regs for this which would then result in me having to redo the whole bathroom i worry. so i decided to leave as is. is this correct interpretation ? |
