Should there be cavity wall insulation in a Bryant built house circa 1996? They have used aircon bricks for the inner skin but surely they aren't enough for decent insulation?
I have just removed the grill from a vent in the lounge and the cold air is whistling through the house!! Even the housing for the through wall vent is loose and removable so I have put a mirror in there and there is no cavity insulation whatsoever.... Would it be ok to seal around the housing with filler foam so that the vent just connects to the external wall vent rather than the entire cavity of the wall as it does now? It's making a dreadful mess of the wall with the dirt blowing in with the cold air.
There are air bricks just above the damp course externally so presumably retro - installing cavity wall insulation is a no no?
