I have an issue with Viessmann, just under 2 years old installed by their approved supplier.
5 months after install the water won't heat, although the radiators were hot, had three visits before they got it right and then.
After about another 5 months would come up with a fault F something and just cut out, engineer came and fixed.
Of late water goes cold intermitently and one engineer says its because of the water pressure and then changed his mind to some debris in the heat exchanger which is not covered under warranty.
Any help would be appreciated
