DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Honeywell CM907 Thermostat problem. Please help.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
hankdesign
from United Kingdom
PostPosted: Wed Dec 08, 2010 8:06 am Reply with quote
Hello all.
I have an issue with the Honeywell CM907 thermostat. I have it set on Automatic and the heating in the house is supposed to turn off at 10pm and not come back on until 6am. However it seems to be going on and off throughout the night and now im worried that I am going to accumulate and huge bill.
Is there some sort of setting to stop this from happening or could it be a fault? Any help will be greatly appreciated. We are in a brand new house and its only 4 months old.
Thanks.
Back to top
 Alert Moderators
MJN
from United Kingdom
Thanked: 63 times
PostPosted: Wed Dec 08, 2010 10:36 am Reply with quote
There might be a misunderstanding here of how these programmable thermostats work.
They do not have 'on' and 'off' times as such, but rather temperature set points. Thus, between 9am and 10pm the temperature set point might be 21C, however between 10pm and 9am your stat might be set at 15C. During 'normal' weather conditions this might be for all intents and purposes be 'off' however during this particularly cold period the house (or the room the stat is in) could be dropping below 15C hence the boiler is being called for heat.
Check to see what the temperature set point is for the overnight periods, and lower it if you don't want the boiler firing.
Mathew
Back to top
The following user says thank you to MJN for this useful post:
hankdesign (8 Dec 2010)
 Alert Moderators
hankdesign
from United Kingdom
PostPosted: Wed Dec 08, 2010 10:43 am Reply with quote
Mathew
Wow that explains a lot. Now you have mentioned it I think you are right. We werent shown anything about the thermostat when we bought the house.
So if I set the temp at around 10c throughout the night it will hopefully not come on. I will test tonight and report back.
Thanks.
Back to top
 Alert Moderators
MJN
from United Kingdom
Thanked: 63 times
PostPosted: Wed Dec 08, 2010 11:02 am Reply with quote
No worries. It is a somewhat alien concept to those used to traditional on/off controls and you might be forgiven for wishing things were nice and simple. However, if you take your time to understand it you will soon appreciate the potential benefits of having different temperatures at different times of the day.
If you haven't already got a copy of the user guide you can download it here. I recommend giving it a good read - two or three times if necessary - as its operation does become fairly straightforward once you've got a little used to it. Check out the holiday/party functions too - very handy things to have but I dare say a great many are unaware of their existance.
Mathew
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replace old Honeywell Thermostat with CM907 3 60 Sun Sep 07, 2014 9:22 pm
Help please re.Honeywell CM907 7 Day Programmable Thermostat 13 1480 Wed Sep 17, 2008 1:29 pm
Help please wiring Honeywell thermostat CM907 14 2800 Mon Jan 26, 2009 5:13 pm
Changing Honeywell T6360B thermostat for CM907 - PLEASE HELP 5 900 Sat Oct 16, 2010 5:32 pm
Replacing a old Honeywell Room Thermostat with a CM907 2 60 Sun Jun 08, 2014 4:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
