Accenta G6 wouldn't shut up
10 Dec 2010
London
Hi there, my neighbour's alarm went off and wouldn't shut up. Knocking on the door didn't help so I was about to go at it with a 2x4 thinking the property was empty when the door opened and a lady popped out. (No not like that).
OK story over, tech bit.
The panel was lit but the day, power and tamper lights on the keypad (remote version ) weren't.
Panel looked slightly open on the clip side which I thought might have set it off.
Tried the factory user code, wouldn't work and she didn't know the current usser code (if there is one). Engineer reset didn't work either. Finally disconnected the bell wires and battery which shut the mother up, decided to leave the strobe going so they remember to do something about it.
Being neighbourly I thought I'd find out how to reset it and why those lights (day, etc) aren't lit.
Any suggestions welcome.
I'm off to bed now 01:23hrs :rolleyes:
You say you tried the factory codes, and engineer codes.
You must have the wrong ones.
Time for someone who knows the panel.
Got the codes from the landlord today but nothing happens. Still wondering why the keypad backlight is on but none of the indicator lights work (day, tamper). Any ideas?
Never been serviced
Duff battery
Damaged cable
The list goes on
but ...... I'd go for the first two
or it could be a failed SAB module,
that will lock out RKP on startup.
change the external sounder/strobe unit
change the battery
try again
if not a very large metal object at about 5 paces might fix it, but if it doesn't, it will shut it up!!!
agree, it could be a multitude of things.
The fault must be rectified before you can bring it out of lockout
Who's the pitiful man who keeps de-rating mine and alarms posts.
Get a life, stop hiding behind a thumbs down
as i said above.
it could by the bell box,
also if you have no indicators on the remote keypad, it could be the aux fuse
1.6AMP 20mm glass type.
also change the battery as well while you are at it.
codes will not work on the system if there is no power to it!!
post again if you need any more help.
Oasis
