DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
GU10 Spots
This topic originated from the How to page called Types of Light Bulb
Click here to return to the page called Types of Light Bulb.
  View previous topic :: View next topic
Author Message
badgercrewe
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 06, 2005 11:41 am    Post Subject:
GU10 Spots
Reply with quote Thanks
Why is it that every time a GU10 bulb blows, it trips the entire light system?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri May 06, 2005 12:29 pm    Post Subject:
Not just GU10s - any bulb can do that.
Fused bulbs can help, as can swapping the MCB for a Type C.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 16, 2005 3:58 am    Post Subject:
GU 10 are crap anyway, but this is unlikely to be the only lamp to take the trip out. Use branded lamps, generally last longer
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon May 16, 2005 10:48 pm    Post Subject:
Here I am, wearing my Osram hat again......
You need lamps with Ballotini fuses so that they will blow instead of the circuit protective device.
Oh, and if you have a dimmer, you def need fused lamps, cos GU10's are good at toasting dimmers when they pop.
MK used to have fuses in their dimmers, but no more, so be warned.
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 17, 2005 4:29 am    Post Subject:
Good advice from Simon, the only flaw is that GU10's do not contain Ballotoni fuses unfortunately, however his comments about Osram are valid, these are the best lamps you buy.
I would also consider getting the lighting circuit looked at, a properly designed and installed circuit should not usually suffer this problem, they can, but rarely.
__________________
I only do commercial and Industrial so Prescott can shove his Part P tax
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 17, 2005 11:26 am    Post Subject:
Another thread where I've found a notification of a post which has since been removed.
Now forgive me if I'm being dim, or insensitive, but I can't see anything here which could have caused someone to react with an "inappropriate" post - ¿que pasa?
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
GU10 Spots in Place of LV DL 14 720 Tue Jan 15, 2008 10:40 pm
Fireproof bathroom spots 4 420 Tue Jan 17, 2006 9:54 pm
LED spots 2 420 Fri Dec 09, 2005 7:25 pm
Bathroom light-fitting spots. 15 740 Thu Dec 08, 2005 10:38 am
ceiling spots 2 320 Mon Feb 27, 2006 10:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
