Hi
I have a 21.5mm condensate pipe that has recently froze a few times.
It runs externally about 1m at approx 10deg drop into my upper guttering. this has consequently caused 4" block of ice in my guttering too. i decided to pull it up slightly and rest it on a tile so there was a gap of about 4" from guttering but it froze anyway as the water reached the opening and cause an ever growing icicle then backed up the pipe and froze! This is even with foam lagging on.
I was wondering what the ideal method of stopping this is.
Can i put a 45deg elbow in, run it round the corner of the house and insert into drain pipe with a boss strap ?
If so, can i do this with overflow pipe or do i need to convert to 32mm ?
Ideally i want to stop it dripping into the upper guttering as i said it causes blocks of ice and i have visions of it getting to heavy and the guttering to fall with the weight, and its the most exposed corner and freezes at the opening.
Thanks in advance for any advice.
Martin
Martin
