hotpoint washing m/c aquarius WMF740 7Kg
4 Jan 2007
My machine has recently developed a problem,
fault F05 flashing on display towards the end of a cycle.
Machine a year old.
Any advice would be appreciated.
Filter blocked /drain pipe or waste spigot
apologies for the stupid question, where is filter located??
1 of 2 places depending on the drum , remove the kick strip at the front.right hand corner is there a twist filter if not remove rear White lower panel and there's a black rubber cup with a jubilee clip round it.
have located twist filter.
can only turn anti clockwise 1/2 turn!!
is this normal, dont want to force it.
Theres coins jammed in there. Tip mc back and twist the filter left to right to unjam it, it should undo freely once it's out.
A big thank you.
Followed your instructions. Turned out to be a jammed nylon stocking!
I am back in the game.
Thanks again. Merry Christmas
You frightened me for a minute there.
We had the same machine installed two days ago.
Must stop wearing my nylon stockings then. :(
Merry Christmas
