Hi
I have tried to look for this problem on the forums, but not had any luck (probably me going blind).
My Glow worm Compact 100e is playing up, and has been for weeks, but seems to be getting worse. Basically, when you turn the hot water taps on, the red LED for the hot water doesn't go off again afterwards and the burner keeps going, and the water becomes boiling hot. This leaves me with no heating. I was overcoming this problem by quickly turning on a cold tap, and this switched the red LED off, and the boiler went back to normal. Today, this didn't help and it kept locking out, so I have turned the boiler off. I left the boiler for about an hour and went back to it, to see if it had helped, but the hot water is still on constant burn up. I have checked all the taps are off and have tried turning on different cold taps to try and flip off the hot water.
Cold weather is coming back and I am keen to get it sorted cheaply.
I have only been in the house 7 years and have had a £600! (I was ripped off!) and a £200 (last year) bill for repairs and I can't afford a new boiler. I had a timer and new PCB board fitted last winter. But on the other occasions I have had water dripping out of the boiler, but this isn't happening this time.
One year I called out a plumber who had been recommended, but have lost his number, when I had the same problem that I am having now, and he just took the panel off the front of the boiler, flicked something inside (around the middle of the upper boiler) and it was sorted. Happy days, and only £20 to do it. I would like to do this myself as it involved no tools etc. I am worried about getting a big bill (after being ripped off before)for something I could do myself, safely.
My boiler pressure is 1.5 bar and I know how to increase if necessary (but not how to decrease it).
Can anyone help me out, pretty please?
Thank you in advance
Debbie
Debbie
