Hi Folks
My Victorian terraced house opens directly onto the street, at a 15deg turn in the road, with 3 steps from (incl) road level up to the front door level (incl), set in a brick porch.
During recent building work, the fella managed to crack the large curved central step, that is somewhat triangular in plan, tightly fitted with a small cut out for a rollback on the front elevation which forms a curved pillar on one side, and separated from my neighbour on the other side by a half brick wall. Anyway, it's a complex shape, so I have thought the best way to replace would be to cast in situ. First, grind out the old step, then create a metal framework bolted together and either side into the brickwork, with 1" or so angle irons, put some kind of thin boarding in sufficient to fill to the spaces between the metal bars and also support concrete tipped in to the top, with some wooden formwork at the front.
I have full access below into my cellar, and have had some metal grilles made up to insert as risers to give good ventilation.
1) Are there any types of steel/finish I should avoid to prevent chemical reaction/damage with the concrete?
2) What sort of mix/product name of concrete should I use? I think standard Portland 4:1 may be a bad idea, considering the heavy use and potential for chipping.
3) Should I use a different concrete material for the topmost layer to give a finer finish?
4) How do I ensure a really flat top/sharp 90deg angle to the front?
5) How to make sure it cures properly -need something reasonably fast as potential for local children to sit on it.
Many thanks...
Many thanks...
