I have a Gainsborough 400X which has started cycling hot / cold. No discernable difference in volume flow during this cycling. Have noticed over the past few weeks the temp getting hotter on the same temp setting. Any ideas?
ban-all-sheds said:Heater can getting furred up - overheats, safety cutout operates, water cools down, safety cutout closes, cycle repeats.
Can you stop it doing this by using a lower heat setting, or a higher flow rate?
If I alter the flow rate round to a hotter setting, the water flow almost stops completely.....
How old is the shower?
Don't know - it was in when I moved in which was a year ago last Sept.
Hard water area?
crafty1289 said:new heater would cost most of the cost of a new shower.
