Gen 4 programme problem
20 Dec 2010
Aberdeen
Can someone assist please have gen 4 system installed manual says if engineer has set up I can use programme 1 ,2, or 3. When I press. My code then p the key tones are supposed to silence then i can chose which programe , only programme 1 appears. Sand key tones do not silence when I press 2 for programme 2 nothing happens, the manual says if engineer has set up. I have engineers annual and canst see where to set thisnup
Pages 34 to 40 , you have to say which zones are being used ( or not) , how they react ( timed ,immediate etc), and most importantly the exit mode (timed , silent etc).
I have read the manual and carried outn the instructions, but when I set the alarm then p for programe we cannot get it to set on programme 2 or 3. The key tones are supposed to silence then allow you to select a programme
Only programmme 1 is offered
When programming exit modes, you have to change it from the default, which is disabled.
Usually, for a part set you would put timed or silent timed.
All we need to do is part set the system for bedtime we want to disable the upstairs zone. I can do it a convoluted way by set, omit the zone and set. But would prefer a I button or 2 max or night time set
You do have the correct engineers code don't you?.If so then all you have to do is read the instructions , and program as desired , there is nothing to stop it working :)
try this..
press PROG , enter eng code **** ,
press PROG , 3 (this chooses program 3)
press 6 ( this is exit mode)
press 3 ( this is silent set )
press RESET 3 times ( gets you out of eng mode).
Use your user guide to set program 3, it should silent set.
