- Joined
- 9 May 2005
- Messages
- 8
- Reaction score
- 0
- Country
Hi, hope someone can help, either in terms of advice or giving me an idea of whether I need a decorator, a spark, or both. And what it would cost.
Wife has decided that door into spare room needs to be rehung, before fitted home office goes in. So the light switch needs to be on the other side of the door.
As far as I can work out, I need to drill and chisel a space for a new mounting box, then drill/chisel upwards to create cable space until I get to door height, then drill/chisel across the top of the door until I'm directly above the old mounting box (probably a good idea to turn the leccy off first!) Then I need to find the cable in the wall somehow, cut it, splice in more cable with some kind of gizmo that can sit in the drilled channel, fit the cable to the new box and replaster over all the drilling.
Does this sound roughly right? What will go wrong? Am I missing any obviously better ways to do this?
TIA
TIA
