Pipe type n size for Condensate pipe ???
21 Nov 2005
Sheffield
Need to change the existing pipe that has recently froze and fractured, any ides on size n where to get from, local like bq wickes etc
cheers
sie
There is no pipe size called "n".
Pipes are measured in mm !
explain 'Chav' ????
sounds like you lot are still on the old motorla flips with extendable aerial !
come on get with it, old lads
21.5mm.........thats millimetres not the rap artist,or ask for overflow pipe at plumbers merchants!
40mm n make sure it's solvent weld n make sure u av enuff fall, u mite find u av 2 do sum drilin if s not that size atm...
explain 'Chav' ????
I dont suppose a Chav would know, but those Motorola extending antennas were made of plastic had no effect when extended apart from kooking nice! I still have a Motorola "brick" analogue phone. They were so sensitive they would work on the French coast from the Channel Isles about 21 miles away.
Tony
