I had to drain my heating system to fit a new 3-port motorised value as the old valve had sprung a leak. This fitted fine and appears to work. However, on refilling the system I appear to have air in the pipes (microbore). The radiators are bled but when the boiler runs for a couple of minutes you hear the air near the boiler (quite loud) and it then cuts off in Overheat mode (Baxi Solo). How can I get rid of this excess air? A colleague has suggested turning the thermostat down and running the pump for 10 minutes with the valve manually open to push the air through the system. However, where is the best place to bleed this excess air? Is this the best solution?
