HI
CAN SOMEONE HELP, MY vaillant 828E BOILER IS NOT GIVING ME HOT WATER,CH IS OKAY,BOILER IS REGULARLY SERVICED,ALSO CALLED AN ENGINEER OUT WHO COULD NOT DIAGNOSE A FAULT AS THERE WAS NO CODE, CHANGED DHW HEAT EXCHANGER, DIVERTER VALVE SEEM TO BE OKAY (NOT SENDING HOT WATER TO CH) NTC CHANGED,WARE SHOULD I BE CONCENTRATING ON, SHOULD THE AQUA sensor BE CHANGED OR CAN THEY BE CLEANED, WORKS A BIT BETTER ON REDUCED WATER PRESSURE,
FEEL LIKE RIPPING IT OFF BREAKING IT TO BITS AND SEND IT BACK TO VAILLANT,
