sky smtp settings outlook 2007
18 May 2010
Belfast
i was on talktalk, just changed to Sky broadband. I have changed the outgoing smtp settings to smtp.tools.sky.com
I have checked on the sky website and this is the correct outgoing address.
i can receive mail ok but when i try and send i get the error..
Task '[email protected] - Sending' reported error (0x8004210B) : 'The operation timed out waiting for a response from the sending (SMTP) server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
that looks ok for outgoing server:
incoming should be pop.tools.sky.com
in further settings you should set incoming server to 995 and outgoing to 25
and a tick in the box for 'my server needs verification'
have you set up on sky email as well..?
i have not setup sky email, this email is for mail from my own website. will the incoming mail server still stay the same as pop3.mywebsite.co.uk
thanks
in advanced - outgoing mail port should be 465 and SLL box should be ticked for outgoing also.
in servers - outgoing mail server - 'my server requires authentication' box ticked. then in settings - you need to tick 'login using' you need you put your 'SKY Username and password'
which will be '[email protected]'
this will be the same username and password you use to login to www.sky.com email system.
if you dont have it, you will need to ring sky to get it.
hth's
