Problem with preset entry time - scantronic 9448+
1 Jan 2011
London
My scantronic 9448+ does not allow for preset entry time whenever part set but does allow when full set. Thus it sets up external alarm before reaching the remote keypad. I have reprogrammed it several time using engineering programming mode to no avail? what could be wrong? what else can I try?
Is your PIR set for Entry/Exit?
From Engineering mode press 52 enter - then 1 enter (double beep) then try it again.
I have solved the problem after following the instructions under engineering programming mode from downloaded manual.Thanks for your earlier reply
