Kitchen Drainage
12 May 2005
Hampshire
I recently noticed a nasty smell in the kitchen, which resulted in me finding the drain outside full up and overflowing.
Upon emptying the drain (manually) and reaching to the bottom, I put my hand in to clear it and seemed to hit the ground (I.e. this appears to be a soak away and not a drain).
Should the kitchen waste (only and sink and dishwasher) go into a proper drain.
This is the only drain near to the kitchen which has been there since the house was built (1930 ish).
any help appreciated :confused: :)
If you'd felt up the side of the hole you'd have found the exit pipe, which will go to an inspection chamber (manhole) of some sort. There was probably a lot of gravel and absolutely foul smelling crud in the bottom? That's yer anaerobic bacteria for you ! It's a crude sort of trap, to stop the sewer smells coming back up.
They do get pretty blocked, especially if the house is pebbledashed, or there isn't a guard round the grille.
Many Thanks, I will look for an exit hole from that drain, although I could not find last night, but it was late and smelly :D
Pour a large bucket of water from as high as you can into the drain several times to shift any ....... :D
Been there done that but will try anything twice to shift the ........ smell. :evil:
Many Thanks for the advice people, I have found the exit hole to the drainage pipe.
It is clogged with cxxx.
thanks again for the assistance.
:LOL:
