part setting texecom premier
18 May 2010
Belfast
can anyone advise how i can setup my texecom premier for night time use. i want to omit just the landing PIR. I know how to omit zones but on my parents alarm system they could select zone A or B etc.
Whats the best way to do this?
thanks
Hello Mate,
I'm in the process of TRYING to set mine up at the moment.
Is the landing PIR on a separate zone?
I THINK you just need to set up an "Area Arm Suite" that includes the Areas with the sensors and stuff from downstairs but not the area that the landing PIR is on.
Have you got the manual? If not just Google it, that should help you a bit
I want mine to only sound the internal sounder in night mode. Do you know how to make it do that?
i want it that if any of the downstairs PIR's are set off then the internal and external sounders will go off.
il have a look on google. i have got the manual somewhere, il have to dig it out.
If the Landing PIR is on a separate zone then you can just use the Part Arms.
Just turn off that zone for the chosen part arm, and name it Night Setting or something.
