DIYnot
Local | Network
   DIYnot > Forums
Local | Network
FLOW PIPE HOT RETURN PIPE COLD DOWNSTAIRS
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
largey212
from United Kingdom
PostPosted: Tue Jan 04, 2011 8:38 pm Reply with quote
HI
IM IN DESPERATE NEED OF SOME ADVICE PLEASE HELP
I HAVE RECENTLY HAD A NEW BOILER FITTED A KESTON C36 AND THE PLUMBER DIDNT DO A POWER FLUSH AND I WAS GETTING A PROBLEM WITH MY FLOW AND RETURN PIPES DOWNSTAIS.
SO ME AND MY FATHER IN LAW RENTED A POWER FLUSH AND DID IT OURSELFS AS WE R QUITE HANDY AND BOTH BUILDERS.
ALL THE RADS UPSTAIRS NOW ARE FINE AND RED HOT BUT DOWNSTAIRS THE FLOW PIPE IS HOT AND THE RETURN PIPE IS COLD BUT THE 1ST RAD DOWNSTAIRS IS HOT AND THE 2 AFTER THAT ARE COLD BUT THE FLOW PIPE UP TO THEM ARE HOT.
I CANT WORK OUT Y THE RETURN IS COLD IF THERE IS HEAT GOING THROUGH THE RAD
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Tue Jan 04, 2011 8:42 pm Reply with quote
try shutting upstairs rads and leave downstairs open.
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 883 times
PostPosted: Tue Jan 04, 2011 8:44 pm Reply with quote
Balance the system but turn off caps lock before you do anything.
Back to top
 Alert Moderators
morlomanc
from United Kingdom
Thanked: 7 times
PostPosted: Tue Jan 04, 2011 8:45 pm Reply with quote
turn upstairs rads off, leaving 2 cold ones on downstairs.
Back to top
 Alert Moderators
terence7556
from United Kingdom
Thanked: 284 times
PostPosted: Tue Jan 04, 2011 8:46 pm Reply with quote
look inboiler/ central heating FAQs at the top of the page items 1-5, especially number 5
Back to top
 Alert Moderators
morlomanc
from United Kingdom
Thanked: 7 times
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 695 times
PostPosted: Tue Jan 04, 2011 8:51 pm Reply with quote
largey212 wrote:
HI
I wish you luck...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
40 kw boiler water flow & return pipe diameter 14 300 Fri Jul 20, 2012 9:41 am
should I extend 22mm pipe on CH flow & return or leave 6 80 Fri Mar 29, 2013 1:21 pm
28mm pipe boiler flow/return 48 4640 Fri Mar 18, 2005 1:41 pm
CH flow and return pipe sizes 4 660 Mon Jun 01, 2009 9:21 am
Flow and Return Pipe Spur 2 40 Thu Nov 22, 2012 6:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
