DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Low voltage cable in walls
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
Vogon
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 13, 2005 2:44 pm    Post Subject:
Reply with quote Thanks
I am having a new kitchen put in, and I want to have 3 x 35W low voltage halogen downlights underneath the wall cabinets.
The plan is for the transformers to be in the plinth under the base units, and there is no problem running mains power to the transformers. However, I need to get LV wires from the transformers up to where the lights will be (each light must have a run of wire to a transformer), and obviously I want the wires concealed in the walls.
My kitchen installer is planning simply to put a plastic conduit in the wall and have the wires coming out at each end (at the top end, this will be just below the bottom of the wall cabiets at the join with the wall) without any connectors. I expect this is not in accordance with the regs, but
1) is it dangerous in any way?
2) is it likely to make an ugly hole in the plaster whcih will get bigger if the wires are jiggled around?
3) is there a better way of doing it?
I should add that the wall units do not have a lip at the bottom to conceal things, so I am not keen on anything bulky in the wall where the wires come out.
All help / suggestions gratefully received
Vogon
P.S. I am aware that (as per the instructions in the lights) the LV wire must not exceed 2m in length. This can be achieved with 2 transformers, with one of them having 2 sets of LV wires going to 2 lights.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 13, 2005 2:52 pm    Post Subject:
Assuming by LV you mean ELV like 12 or 24V (415/240V is an "LV" in most power books) it likely to be OK, but perhaps a back box should be in the plaster or on the wall at each end of the tube, so that the cable has something to emerge into neatly, particularly if you think fiddly fingers might get to it.
For mains cabling the route should follow the line of least surprise, i.e. vertically or horizontally between inspectable points, unless you really can't in which case it needs to be protected by an earthed screen or conduit. (or within 6" of a wall corner or ceiling....)
It is possible to put a blanking plate over hidden corners to make this true, providing the change in direction of the cable can be deduced when you remove the covers, and this can be a handy 'rescue' for a dodgy cable route.
__________________
regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs-
Back to top
 Alert Moderators
Vogon
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 13, 2005 3:08 pm    Post Subject:
Thanks, yes I mean 12V.
Vogon
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Running cable in stud walls 2 820 Wed Apr 28, 2004 9:45 am
Burying Cable in In Plastered walls? 6 820 Sun Oct 02, 2005 10:45 am
mains-lighting-smoke alarm cable in new stud walls 3 640 Sun Jun 19, 2005 11:35 pm
Running Cable in Cavity Walls... 4 940 Tue Aug 29, 2006 3:27 pm
Running cables behind plasterboard walls 5 2520 Tue Feb 19, 2008 7:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
