Hi all,
i'm wondering if i can wire in my cooker, or do regs require a qualified spark to do it?
i'll need to take out the old switch and join the wires - i presume these will need to be crimped together with butt connectors (will they need a heat shrink too?), cover this hole with a blanking plate, take a cable to the new switch located in a unit, run a cable back to the terminal behind the cooker. i'm fairly good with electrics, but unqualified. should this be done by a qualified person for regs, much like fitting gas appliances?
reason i ask is that in my old house an unqualified builder did this and said it would be fine.
cheers,
cheers,
